Jimny to many RPM on highway - Higher gear ratio
09 Jan 2012 16:52 #30383 by Obarno
I've never seen higher ratio gears for the transfer box but the European diesel Jimnys use a higher diff ratio which I am pretty sure is 3.4 so that could be another option. I don't where in the world you are but in the UK the VVT transfer boxes aren't particularly expensive 2nd hand. You could try Cam Suzuki as they would always have them.
  • peter5floor
09 Jan 2012 16:59 #30386 by peter5floor
Ok interresting, .. maybe I should try to find one of these. thanks :)
Btw im from Denmark.
  • 247sniper
09 Jan 2012 18:06 #30391 by 247sniper
That speed with your RPM will actually do the engine good, apart from the fuel consumption, very little load at that speed but with a lot of momentum :)
Steve.
  • wanderinstar
26 Jan 2012 15:07 #31908 by wanderinstar
Replied by wanderinstar on topic Re: Jimny to many RPM on highway - Higher gear ratio
Why don't you want to fit bigger tyres? You wouldn't have to go for the 31" Just say 215x15. Will give you a slightly better MPG I would have thought, but not look to bad on the vehicle.
  • ZookFastback
26 Jan 2012 19:44 #31930 by ZookFastback
Replied by ZookFastback on topic Re: Jimny to many RPM on highway - Higher gear ratio
The Jimny G13BB motor is designed to run all day at 4000 revs/100 kph. That is its heritage from a M/bike manufacturer. Without those revs you would not be able to overtake or zoom over hills.
My Jimny sits on 120kph in the Territory for months at a time, one would never get anywhere otherwise. When I go to Adelaide every month (800kms each way), the Jimny sits on 110kph towing a teardrop caravan. Without those revs I couldn't do it. Would have to pull over to let a line of cars go past me.
Accept what you have, ignore the revs or put a picture over the tacho so you can't see the revs ;)
Keep the oil up to the car, change every 5000 kms. Put decent platinum spark plugs in and change the air filter/oil filter when you change the oil and you will have no problems.
I've been driving mine for 11 years with no hassles and only 2 parts broken down in all those years.
26 Jan 2012 21:24 #31942 by kirkynut
ZookFastback wrote: The Jimny G13BB motor is designed to run all day at 4000 revs/100 kph. That is its heritage from a M/bike manufacturer. Without those revs you would not be able to overtake or zoom over hills.
What he said!
By the time you've paid for an electrically operated transfer box and worked out a way to make it work in a car it wasn't intended to go in, you could have bought a car that had one from the factory! It would likely have Variable timing also, which may save on some fuel.
The first motorway journey I had a Jimny was in an early single cam hard top model and my thoughts were not too diferent to yours, but these cars were not designed to sit at speed for long but the engines are designed to be able to rev like that.
Bigger tyres will not aid fuel consumption anyway as it will take more effort and thus fuel to get up to speed and you will miss the acceleration you have now - not that it is that impressive in the first case.
So I would just accept what you have and make the most of it.
Also, you do need those revs to keep it in the powerband up hills on motorways!
Time to create page: 1.493 seconds
