gear stick woble
- b2nrc
30 Dec 2011 13:32 #29507
by b2nrc
gear stick woble was created by b2nrc
hi
new to this fourm i have just changed the clutch on my 52 plate jimny everything works but the gear stick is wobley when in or out of gear and hard to to find 1st but was not like this before i took it apart i can not see any thing wrong with any help would be great
thanks
neil
thanks
neil
- r_ogilvy
30 Dec 2011 17:54 #29520
by r_ogilvy
Replied by r_ogilvy on topic Re: gear stick woble
did you take the gear stick out of the gearbox? or did you just drop the gearbox?
- b2nrc
30 Dec 2011 19:32 #29526
by b2nrc
Replied by b2nrc on topic Re: gear stick woble
hi
i took the stick out of the remote housing then removed the remote housing so i could get the gear box out put everything back together and the stick wobles in or out of gear like if the stick isn't bolted to the housing
neil
neil
30 Dec 2011 21:10 #29533
by dirtydogz
2002 JLX Soft Top
Replied by dirtydogz on topic Re: gear stick woble
Did you put the nylon bush back on the end of the gear stick when you but it back in the gear remote housing, some times it drop off in to the grease next to the gear selector.
2002 JLX Soft Top
- b2nrc
30 Dec 2011 21:13 #29534
by b2nrc
ok thanks there wasn't one there when i took it apart will have a look in the morning
thank you
neil
thank you
neil
- r_ogilvy
30 Dec 2011 21:30 #29537
by r_ogilvy
yeap cheak this they can be a pain
dirtydogz wrote: Did you put the nylon bush back on the end of the gear stick when you but it back in the gear remote housing, some times it drop off in to the grease next to the gear selector.
Time to create page: 0.168 seconds
