survice help
  • nicho
29 Dec 2011 08:15 #29408 by nicho
survice help was created by nicho
could someone put a list of to do,s for a anual survice guna do ours again soon last time only did air filter oil filter plugs and pads,only askin coz i keep reading bits such as prop grease etc.
  • 247sniper
29 Dec 2011 09:00 #29411 by 247sniper
Replied by 247sniper on topic Re: survice help
- Engine oil and filter
- Air filter
- Spark plugs
- Brake fluid, change and bleed. Usually every 2 years, more so if your off roading often.
- Anti freeze, every 3 years recommend, but I do it more often than that.
- front and rear axel oils, gearbox and transfer box oil.
- Greece prop shaft.
Not in the manual to replace it as a service item but from my experience replace the PCV every 3-5 years depending on mileage, better to prevent then to cure!
Steve.
  • Foxtrot
31 Dec 2011 21:15 - 04 Jan 2012 20:16 #29623 by Foxtrot
Replied by Foxtrot on topic Re: survice help
Hi Nicho, I have scanned an official Suzuki service check list which is very comprehensive. At the top has the yearly/mileage intervals and down the side what needs checking/replacing
Attachment OfficialSuzukiServicechecklist23.pdf not found
Last edit: 04 Jan 2012 20:16 by Foxtrot.
  • SOTA
31 Dec 2011 22:26 #29624 by SOTA
Replied by SOTA on topic Re: survice help
Excuse my ignorance, but what is a PCV?
  • Foxtrot
31 Dec 2011 22:31 - 31 Dec 2011 22:48 #29625 by Foxtrot
PCV is short for positive crankcase ventilation, it can cause you a lot of grief if it goes faulty, see the link below that explains what it does, and here is a photo of one from my Jimny when it did go faulty at approximately 45000 miles. Suzuki dealerships check them at 6 years / 54000 miles if you have your Jimny regularly serviced.
www.agcoauto.com/content/plugins/p2_news...php?p2_articleid=197
Attachment DSCF0414-400_2012-01-01.jpg not found
Last edit: 31 Dec 2011 22:48 by Foxtrot.
  • 247sniper
31 Dec 2011 22:34 #29626 by 247sniper
It is, PCV ( positive crankcase ventilation valve) . Not listed as a serviceable annual replacement part but for about £20 its worth replacing every 3-5 Years though to maintain engine running, performance and condition.
Steve .
Time to create page: 0.445 seconds
