Engine Diagnostic's
- Jamie
29 Mar 2010 12:06 #2924
by Jamie
Engine Diagnostic's was created by Jamie
Hi there everyone,
No emergency at the moment this is for future reference only,
does my Jimny M13A VVT still use the OBD2 code reader i am going to
get one but i need to make sure it will work in my car.
Also any recomendation's as to which one to buy, From what i read
not the Snap On Solus model.
Thank's
Jamie
Thank's
Jamie
12 Apr 2010 09:55 #3104
by Rhinoman
Replied by Rhinoman on topic Re:Engine Diagnostic's
I think that we could do with a register with anyone who has tried a scantool to post whether it works or not. I'm trying to investigate this issue, it seems to affect all Suzuki OBD2 models. It did seem that the Elm based scan tools were a fairly safe bet but I have now heard of at least one Elm based tool that doesn't work either.
I really need to borrow a scan tool that doesn't work to pursue this further.
12 Apr 2010 18:44 #3110
by kirkynut
Replied by kirkynut on topic Re:Engine Diagnostic's
I have just bought the one Martin has, have a look at his article on it. It seems really easy to use and although I have no trouble codes at the moment I am confident it will work as it has done for Martin. They are £91 at the moment! Bet you can't find one cheaper that works!!!
13 Apr 2010 07:23 #3117
by Rhinoman
Which model do you have? There is some evidence that early G13BB models may be OBD1.
13 Apr 2010 15:45 #3119
by Rhinoman
Rhinoman wrote:
Now verified. So if you're looking for a scanner first you need to determine if you are OBD1 or OBD2 by checking which pins on the J1962 (OBD2) connector are populated. If possible you should also verify that the populated pins are wired through to the ECU and have 5V on them with the ignition on. It is not unknown for the diagnostic connector to be populated even when the ECU doesn't support that particular protocol.
www.rhinopower.org/diag/sdl.html
OBD2 scanners are very easy to find but again may not work. OBD1 scanners are not commonly available, the Tech1 and Carman scanners cost several thousand pounds each. I jave been working on software that allows an ALDL style interface to be used and I will at some point add support for the Jimny.
www.rhinopower.org/Rhinoview/Rhinoview.html
Time to create page: 0.172 seconds
