Rubber 90deg Elbow.
- mcjimny
21 Dec 2011 18:05 #28851
by mcjimny
I meant your age not your trucks :laugh: as in i'm not sure if you're old enough to remember old motors with the setup. Old SJs used to have it if i remember, you would undo a wing nut and rotate one side of the airbox.
Its exactly as you describe it, it disappears into the wing then enters the airbox. If you look at it you should see writing and arrows on it.
Replied by mcjimny on topic Re: Rubber 90deg Elbow.
wanderinstar wrote: Mymotor is 02 plate.So is is open in the engine bay, then it goes through the inner wing and is connected via pipework to the air cleaner.Yes it sort of makes sense.
At least these engines don't have the dreaded EGR valve.That Inever could get my head round.
- wanderinstar
21 Dec 2011 18:14 #28854
by wanderinstar
Replied by wanderinstar on topic Re: Rubber 90deg Elbow.
LOL. Ohh, I'm old enough.59. Have investigated it further and as said before the pipe goes into the inner wing area and then comes back into bottom of air filter. Yes all is now clear, Thank you.
- mcjimny
21 Dec 2011 18:16 #28855
by mcjimny
You should remember then!
They still had starting handles when you passed didn't they?
At least you'll sleep better knowing how it works
- wanderinstar
21 Dec 2011 18:30 #28857
by wanderinstar
Yes, had one on the Minor I had about 4 years ago.If I could have got a rot free bodyshell I would still have one now.They were so simple to work on.
Mind you the Jimny doesn't seem too bad too work on,apart from filling gearbox with oil.There has to be an easy way.
21 Dec 2011 20:25 #28872
by dirtydogz
2002 JLX Soft Top
Replied by dirtydogz on topic Re: Rubber 90deg Elbow.
And can you remember the parking light
www.oldcaraccessories.co.uk/Parking.htm
Attachment Parking-lights-001.jpg not found
2002 JLX Soft Top
- darthloachie
21 Dec 2011 21:28 - 21 Dec 2011 21:40 #28882
by darthloachie
cool, I had one of those
and do you remember these?
Replied by darthloachie on topic Re: Rubber 90deg Elbow.
dirtydogz wrote: And can you remember the parking light
Attachment cosmic.jpg not found
Last edit: 21 Dec 2011 21:40 by darthloachie.
Time to create page: 0.294 seconds
