Caster correction + wheel base
  • Nobby22
20 Dec 2011 13:19 #28695 by Nobby22
Replied by Nobby22 on topic Re: Caster correction + wheel base
As far as iam aware castor correction bushes only correct the angle on a 2" lift. For 3" you would need new arms. So what ever bushes you get, poly or rubber, they will be for 2" lift.
I only sujested polybush so if it doesnt work you can re-ajust you angle easily. If you have a hydraulic press to hand rubber ones wont be an issue, getting them in and out.
If you do get polybush Superpro are regarded as the best. Its what i have in mine. Nice and easy to fit ;)
I surpose you realy want to know if it will work before you put them in anyway :)
Nobby
  • renard38
20 Dec 2011 19:07 - 20 Dec 2011 19:07 #28734 by renard38
Replied by renard38 on topic Re: Caster correction + wheel base
look at the difference between the castor correction bushes and the +3" radius arms ( it's more expensive but the better choice ). I had destroyed the castor correction bushes on this picture in only 4 month :S
[img
[img
Last edit: 20 Dec 2011 19:07 by renard38.
  • zukenutter
21 Dec 2011 21:19 #28880 by zukenutter
Replied by zukenutter on topic Re: Caster correction + wheel base
I think if you can find a set of three inch correction bushes that it would definitely work as you suggest. I've been thinking about doing this for my rear axle to nose down the drive input and move the axle slightly rearward for better coil spring dynamics. I've seen 2" rubber correction bushes somewhere.
As for the front don't waste your time on bushes, save the coin and install arms, much better outcome.
  • Nobby22
22 Dec 2011 09:30 #28911 by Nobby22
I could be wrong but i dont think you can get 3" corrected bushes. I guess the bush is physically not big enough to take up the amount of off-set needed.
Nobby
  • Municipal Waste
23 Dec 2011 21:58 #29138 by Municipal Waste
Replied by Municipal Waste on topic Re: Caster correction + wheel base
Are those Zanfi arms you've got there Renard?
  • renard38
24 Dec 2011 08:57 #29149 by renard38
No, the radius arms come from jimnybits ( i only paint them in red )
Time to create page: 0.157 seconds
