hi got a lift question for you boys thanks
  • suzuki jimny fella
16 Dec 2011 21:04 #28399 by suzuki jimny fella
hi got a lift question for you boys thanks was created by suzuki jimny fella
hi
got a jimny with 3" lift es3000 procomps and was wondering how much coil sping spacer i can put under them is it 1.5" or can i go to 2" because coils have setteled down
thanks
16 Dec 2011 21:27 #28401 by mlines
It depends on the shocks you have fitted.
16 Dec 2011 21:30 #28402 by suzuki jimny fella
Replied by suzuki jimny fella on topic Re: hi got a lift question for you boys thanks
es3000procomp shock
  • supergaz
16 Dec 2011 22:12 #28407 by supergaz
Replied by supergaz on topic Re: hi got a lift question for you boys thanks
I've a 3" lift and 1.5" spacers with ES3000 +3" shocks. No problems.
16 Dec 2011 22:13 #28408 by mlines
Pro-comp ES3000 is a range of shock absorbers, not a single shock absorber. You will need the number from the tube.....
ie.
313500
313509
313510
Take a look here for example....
www.procompusa.com/productlist.aspx?plid...&subcat=90&ptid=3306
16 Dec 2011 22:31 #28410 by suzuki jimny fella
gaz do your es3000 come to a stop when you put spacers under coils or can thay come out a bit more
Time to create page: 0.766 seconds
