dual battery setup
- FIRSTJIMNY
13 Dec 2011 20:49 #28101
by FIRSTJIMNY
dual battery setup was created by FIRSTJIMNY
Does anyone have a dual battery setup on their Jimny?
If so, where did you mount the batteries?
Could you possibly post a picture of your setup?
Thanks
Thanks
- r_ogilvy
13 Dec 2011 21:03 - 13 Dec 2011 21:05 #28102
by r_ogilvy
Replied by r_ogilvy on topic Re: dual battery setup
hi, yeah i have.
iv got the standard battary linked to a optima yellow top deep cycle with a t-max split charge system.
i have the optima mounted the oposite side to the standard by making up a mount for it.
excuse the messy wiring just in the middle of wiring a 2nd winch up so have solinoids everywhere
Attachment IMG00403-20111213-2153.jpg not found
Attachment IMG00406-20111213-2153.jpg not found
Attachment IMG00407-20111213-2154.jpg not found
Attachment t-max-split-charge-system-2809-p.jpg not found
Last edit: 13 Dec 2011 21:05 by r_ogilvy.
- Johnniehec
- Thank you received: 56
14 Dec 2011 10:38 - 14 Dec 2011 10:40 #28127
by Johnniehec
Replied by Johnniehec on topic Re: dual battery setup
Hi, I've got a Numax at the other side, made a tray and had to do a wee bit of panel beating to get it to clear the bonnet.
Wired it up to the other one with a fat 400A relay with a switch on the dash so I can jump start if the main battery is flat and let me charge both in parallel which I've never got to work, the fan belt just slips. maybe i need to invest in a split charge system or maybe it's just cos the two batteries are not identical.
Attachment IMG_0131.JPG not found
Attachment IMG_0115_2011-12-14.JPG not found
Attachment IMG_0127_2011-12-14.JPG not found
Attachment IMG_0125.JPG not found
Attachment IMG_0129_2011-12-14.JPG not found
Attachment IMG_0170_2011-12-14.JPG not found
Last edit: 14 Dec 2011 10:40 by Johnniehec.
- r_ogilvy
14 Dec 2011 11:12 #28128
by r_ogilvy
Tidy job. I like it
- darthloachie
14 Dec 2011 16:11 #28139
by darthloachie
Replied by darthloachie on topic Re: dual battery setup
ours is mounted behind the passenger seat
Attachment winch7_2011-12-14.jpg not found
15 Dec 2011 13:44 #28233
by kirkynut
Replied by kirkynut on topic Re: dual battery setup
If you're putting 2 batteries together they ought to be the same size and type and I wouldn't worry too much about a split charge system, just connect them.
I say this as I have one big Numax used heavily many times over with no worries about going flat on a standard alternator, so 2 will be fine negating the need for a split charge.
Also see Martins blog comments about the wiring and the light feed not being used.
Time to create page: 0.137 seconds
