play in steering, not sure but...
- sjwright
20 Mar 2010 07:06 #2766
by sjwright
play in steering, not sure but... was created by sjwright
hi
im no mechanic, and i have play in the steering of my jimny, but checked it out anyway.
My track rod ends seem ok, but what looks like a ball joint on the end of the front drive shaft has quite a lot of wear and surface rust.
Whats the prognosis here?!
thanks in advance!
ste
thanks in advance!
ste
20 Mar 2010 07:45 #2767
Replied by mlines on topic Re:play in steering, not sure but...
I would not worry too much about the wear and rust on your balls :blink:
Jimny steering is renowned for its positve feeling and accuracy :laugh:
Best way forward is to jack up both front wheels at the same time if possible and generally rock the front wheels and steering to see if you can see where the play is occuring.
There are lots of areas that wear occurs from Kingpin bearings, wheel bearings through to the track rod ends.
If it is just steering play there is a pre-load adjustment on top of the steering box itself. Its not a hard job to adjust the pre-load, but it is difficult to access the adjuster.
Time to create page: 0.492 seconds
