Hand brake very slack.........
- teafortwo0789
01 Dec 2011 17:47 #27016
by teafortwo0789
Replied by teafortwo0789 on topic Re: Hand brake very slack.........
I'm not sure using WD40 is the best lubricant / penetration oil for the brake mechanisms.
I prefer to use proper penetration oil to free up parts such as bleed nipples and Copper grease where I want parts to stay free. I find that WD40 dries out and is best kept for electrics and mild lubrication and is also quite good for cleaning bits.
- Back in Black
14 Jan 2012 16:53 #30901
by Back in Black
Replied by Back in Black on topic Re: Hand brake very slack.........
You were all correct - build of mud/clay prevented the brakes from working...
Having gone off roading last weekend I managed to blow one of the front pads out with the pressure washer!! So once I got home started to strip down the front caliper only to find that the pads have completely worn out :blush: , no shops open of course on a Sunday evening! So had to re-build with the old pads. Then moved on to the rear brakes to try and clean them up as advised. Failed!! Couldn't get the drum off! Had my camera ready and everything....
I dropped the car off first thing monday morning at a local garage who replaced the front pads and then emptied both rear drums which were packed solid with rock hard clay and mud! They had to use some pneumatic tool to release the drum!! I will now hopefully be able to remove the drum myself and clean them more regularly.
Thank you for the advice, I promise to clean the brakes after each off roading session.....
- mcjimny
14 Jan 2012 17:56 #30907
by mcjimny
Replied by mcjimny on topic Re: Hand brake very slack.........
Did you try to "drive" the drum off with a pair of bolts? IIRC they're something like m8, you drive a bolt into the hole with your ratchet and it will pop the drum off. Using a pair of bolts and tightening a bit at a time will pull it off even.
As you say, just pull them off and clean them out after any mud session.
- darthloachie
14 Jan 2012 18:33 #30910
by darthloachie
Replied by darthloachie on topic Re: Hand brake very slack.........
best thing we did was fit rear disks - handbrake holds on steep hills even after a few hours offroading
- Mala43B
15 Jan 2012 09:17 #30941
by Mala43B
Ha ha, along with whoever decided to put traffic lights on roundabouts!
Replied by Mala43B on topic Re: Hand brake very slack.........
doncarlyon wrote: Whoever invented drum brakes wants shot in the face with a really big gun!
- Johnniehec
- Thank you received: 56
17 Jan 2012 12:18 #31159
by Johnniehec
And Mr Allen who invented the totally useless "negative" bolt heads!!
Replied by Johnniehec on topic Re: Hand brake very slack.........
Time to create page: 0.322 seconds
