Replacement Keys and Fan Belt Changes
28 Nov 2011 20:42 #26829 by facade
Next time, remove the tap completely, coat with vaseline, or a suitable dry lubricant, graphite if you have fishing rods or silicon/ptfe before screwing back in.
The tap is a great idea: drain the coolant into a clean bowl, and it can go back in after the work is done.
Get a plain key cut at the keybar to open the doors (it will turn the ignition, but the immobiliser will prevent it starting the car.), if you snap your key off, put the plastic handle end on the same ring as the keybar key and it will still work with the immobiliser.
Dont lose the key.
The following user(s) said Thank You: Smoggy
  • teafortwo0789
28 Nov 2011 20:51 #26834 by teafortwo0789
Replied by teafortwo0789 on topic Re: Replacement Keys and Fan Belt Changes
The idea of keeping the handle is a good one as a stop gap if you need multiple keys. Me wife and sons. What is the required proximity for the plastic handle? An idea might be to stick the handle inside the column cover somewhere close to the lock and have a couple of extra keys cut to use as suggested by previous correspondent. I know it reduces security and might enable the system to be bypassed, but better than having only one viable key.
29 Nov 2011 09:36 #26866 by kirkynut
In respect of the rad, I choose to drop the bottom hose as I fear the drain plug will be seized, the rubber seal will be perished or otherwise, leading to probs or a new rad. I use a Jubilee clip rather than re-use the crap factory one.
With the keys, your insurance company may not be too impressed about the transponder being taped to the immobiliser but the car thief will.
  • Glencruich
30 Nov 2011 08:44 #26909 by Glencruich
Replied by Glencruich on topic Re: Replacement Keys and Fan Belt Changes
Good point re insurance company! Obviously, I have now removed the transponder from the immobiliser. In fact, it was never there! :whistle:
We live in the middle of nowhere, but that's no excuse...
  • myers647
30 Nov 2011 17:46 #26949 by myers647
Replied by myers647 on topic Re: Replacement Keys and Fan Belt Changes
Hi mate I only had one key up untill yesturday. I got a normal key without transponder in it cut . This cost me £5. I have got the old snapped key on a keyering with it and it works fine.
Thanks
  • supergaz
30 Nov 2011 18:58 #26954 by supergaz
Replied by supergaz on topic Re: Replacement Keys and Fan Belt Changes
teafortwo0789 wrote: The idea of keeping the handle is a good one as a stop gap if you need multiple keys. Me wife and sons. What is the required proximity for the plastic handle? An idea might be to stick the handle inside the column cover somewhere close to the lock and have a couple of extra keys cut to use as suggested by previous correspondent. I know it reduces security and might enable the system to be bypassed, but better than having only one viable key.
Why not get a thatcham after market immobiliser fitted ?
