Re: Tow bar wiring help please
24 Mar 2022 21:58 #242488
by Scimike
Replied by Scimike on topic Re: Tow bar wiring help please
I did what Dr Robin did. The cables for the bumper lights pass through a hole on the left side viewed from the rear, I followed this route and then cable ties hold the cable on the tow bar. You do need to removed the interior side plastic to get at the route, but all light cables are present.
It's true, the Jimny is a terrible choice for a caravan tow vehicle, but it can do it so long as you're in no rush!
- Thank you received: 1861
25 Mar 2022 04:25 #242490
Replied by Lambert on topic Re: Tow bar wiring help please
I also went down the passenger side under the bumper as the others have done.
As for towing I regularly tow at full 1300kg capacity both single axle and twin axle as I have livestock to move and a moving load is way worse than a caravan that's properly loaded and balanced. Yes it's slow on hills but my Jimny is no less stable or incapable at it's full capacity than my land cruiser is at it's full capacity. Just drive accordingly.
25 Mar 2022 12:22 #242498
by Buzz
Replied by Buzz on topic Re: Tow bar wiring help please
Ok thanks for the replies.
The instructions definitely said to go through the hole above the silencer (and the grommet fitted) although coming down the passenger side would have been a better design.
I’ll have another look at the weekend.
It’s the OEM wiring loom and apart from the routing I’m very pleased - it’s all plug and play with no cutting of the car wiring and power pickup from the rear loom . Definitely would recommend.
Cheers
Cheers
Time to create page: 1.557 seconds
