Rear Bearings and Seals.
19 Nov 2011 23:11 #26145
by facade
Replied by facade on topic Re: Rear Bearings and Seals.
The bearing just drops down the shaft and presses on the last part as you surmise.
They are a pig to remove.
The book says to first grind away two sides of the seal ring (this is easy but time consuming: a coloured stripe appears as the metal gets paper thin due to heating) then use a chain puller from the end of the halfshaft down to the bearing, but I don't have one, so it was smash the race and heat grind and pull the inner race off.
- teafortwo0789
20 Nov 2011 09:12 #26154
by teafortwo0789
Replied by teafortwo0789 on topic Re: Rear Bearings and Seals.
Thanks, seems it might be worth considering a DIY press. I wouldn't mind carrying a bottle jack as it would have a dual role, 4 pieces of angle iron plus two lengths of strip steel could be made to work as a press.
Time to create page: 0.130 seconds
