Nearly stalling on idle - any tips please
09 Nov 2011 21:48 - 09 Nov 2011 21:51 #25497 by Foxtrot
My 2007 Jimny has had a lumpy idle for the last 6 months, it is only when the engine has warmed up, the tacho doesn't drop significantly and there are no engine lights on the dash. If I put it in 1st gear and thrash it briefly it seems to make the lumpy idle less frequent for a few days.I've tried different petrol stations and put in some redex injector cleaner in case it is bad petrol and I've still no idea what is causing it. It looks like it is a common problem on the Jimny :(
Last edit: 09 Nov 2011 21:51 by Foxtrot.
  • 247sniper
27 Dec 2011 22:25 #29335 by 247sniper
Replied by 247sniper on topic Re: Nearly stalling on idle - any tips please
What you need to do is remove the throttle body completely and give it a real good clean, also attached to the throttle body is th IAC (idle air control valve) this is probably the one causing the trouble, it is probably sticking. Give that a good clean too, you should be able to here it click/rattle if you twist and shake it quickly.
Give that a try, from how your describing it that sounds like the culprit .
Let us know how ou get on.
Steve.
  • X-Eng Simon
27 Dec 2011 23:14 #29341 by X-Eng Simon
Replied by X-Eng Simon on topic Re: Nearly stalling on idle - any tips please
I agree with the two others who have mentioned it - idle control valve is what I'd look at first!
Si
28 Dec 2011 11:30 #29361 by Foxtrot
I cured my lumpy idle by changing out the PCV valve, £17:00 :woohoo:
  • 247sniper
28 Dec 2011 11:52 #29363 by 247sniper
Good stuff, where did you get the PCV valve from ?
Steve.
28 Dec 2011 17:29 - 28 Dec 2011 17:32 #29377 by Foxtrot
Hi Steve, I ordered it from the Suzuki dealership Part No 18118-54D00, thats the old PCV valve in the picture but gives you an idea what it looks like. John
Attachment DSCF0414-400_2011-12-28-2.jpg not found
Last edit: 28 Dec 2011 17:32 by Foxtrot.
Time to create page: 1.329 seconds
