Engine Sensors and Wading
16 Nov 2008 19:08 #252 by kirkynut
Dear All,
How do Jimny engine sensors fare when wading?
What do you all normally do to protect them?
I'm not planing on doing any deep wading as I don't plan to get water in the cab - I don't want to remove my carpets! Just need to know in case it happens unplanned if you know what i mean!
Kirky
16 Nov 2008 19:25 #254 by mlines
Replied by mlines on topic Re:Engine Sensors and Wading
The sensors do have a reputation for failing but this seems to be heat orientated, not water. The systems are poor running/misfiring after warming up which can be "cured" by putting cool water on the cam sensor. The only fix is then to replace it.
17 Nov 2008 12:23 #258 by kirkynut
Thanks for that Martin,
So is it that the Cam sensor is the most troublesome then?
How do you find the coil packs? - I don't mean where are they but how reliable are they?
Does the vehicle have a crank sensor?, I guess it does and if so is this not more vulnerable to water when wading due to it being lower down, i'm guessing it is not troublesome as you've not mentioned it.
I have only just bought my twin cam engine 2000 "X" reg jimny and have not had time to get under the bonnet and have a good look around yet!
I have a CD service manual from ebay but again have not had time to study it.
I like to know my vehicle's inside out as much as possible to give me the best chance of fixing them myself and if necessary out in the field.
Also, I am under the belief from KAP and by looking at tghe engine that it has a timing chain rather than a belt - is this concurrent with your knowledge of this age non VVT twin cam 16V engine?
Sorry for the million Q's
Kirky
17 Nov 2008 13:23 #263 by mlines
The engine has both Cam and Crank sensors. As I said, I have never heard of them being vulnerable to water and the one that people mention failing is the Cam one, due to heat.
17 Nov 2008 13:24 #264 by mlines
And I have not heard of coil pack problems either.
  • tree fella
27 Feb 2009 22:16 #432 by tree fella
Replied by tree fella on topic Re:Engine Sensors and Wading
after a good steam clean, clean up any suspect contacts, re-assemble then empty a load of sprayable lithium grease over them it repels the water and stops mud & dust sticking. You have to re-apply it when you wash it off but has worked wonders for me
Time to create page: 0.170 seconds
