King Pin play, but not leaking?
29 Oct 2011 10:23 - 29 Oct 2011 10:24 #24696 by mlines
Elaine wrote:
P.S How do I update my Profile, Avatar & Signature on here? :blink:
Login to the forum.
Look along the tabs at the top of the forum
Select "Profile"
Click on "Edit" (upper righthand side of box)
Adjust what you want, note that an Avatar has to be quite small otherwise it will not upload.
Last edit: 29 Oct 2011 10:24 by mlines.
29 Oct 2011 10:30 #24697 by Elaine
Already tried that... When I click the Edit button my Profile Information, Avatar Image & Forum Settings are all greyed out, unclickable. :unsure: Do I need a minimum post count before I qualify?
E. :)
29 Oct 2011 10:32 #24698 by kirkynut
That's good that you have found the problem of the play - but why did it not leak oil - mine leaks just at the thought of play! Maybe an idea to check the front diff oil level and give it a top up/replace what is in it.
29 Oct 2011 10:38 #24700 by Elaine
Not sure, probably because we caught it really early this time? B)
29 Oct 2011 11:02 #24702 by Elaine
mlines wrote:
Login to the forum.
Select "Profile"
Elaine wrote: Already tried that... When I click the Edit button my Profile Information, Avatar Image & Forum Settings are all greyed out, unclickable. :unsure: Do I need a minimum post count before I qualify?
Way over my head, but it looks like it could be a Mootools Issue?
Scroll to about halfway down the page, How to know if you have a Mootools issue docs.kunena.org/index.php/Javascript_and_Kunena
E. :)
29 Oct 2011 14:13 #24713 by Elaine
My hubby is good to me, he's serviced my Jimbob as well doing the Kingpin. :kiss:
E. :)
Time to create page: 0.189 seconds
