235 75 15 tyres......
  • mark1971
15 years 1 month ago #24003 by mark1971
235 75 15 tyres...... was created by mark1971
235 75 15 tyres.......is there a definite answer as to whether these fit onto a jimny with a 3" lift?? I've read loads of posts on this forum across a wide time frame and every post seems to have conflicting info regarding fitment. My 195 80 15 muds are going to need changing in the not to distant future and I want a taller and wider tyre on my jimjam. Mine is an early 2005 model that has the bumper that features on earlier models with the fog lamps fitted, not the later bumper that hangs down lower and looks like its fitted with plastic vents. Will a 235 rub on full lock or catch when I'm doing mad stuff off road and clearing axle twister sections?
My head hurts......
Mark
  • doncarlyon
15 years 1 month ago #24004 by doncarlyon
Replied by doncarlyon on topic Re: 235 75 15 tyres......
Suppose it will depend on wheel offset, etc. But you could use spacers if required.
I have 215 80 15 Insa Turbo Saharas and they dont catch on the front but do rub on the rear at maximum flex or with people in the back when cornering.
15 years 1 month ago - 15 years 1 month ago #24011 by maverick
Replied by maverick on topic Re: 235 75 15 tyres......
I have 16" GV rims and 205/75/16 (tyres are about 32inches across) ... AND 32mm Wheel spacers and YES they DID rub some..... so out came the BFH.
I had to get the BFH on all the inner arches, seams, anything that was rubbing, there was also a slight 'rub' on the chassis rail under the headlamp - I've BFH'd that a bit and its better, but in an ideal world it would need cutting/shutting and re-welded back up.
I also have ProComp ES9000 shockers that restrict movement - and these work well.
I suppose the best way to find out is to 'borrow' a wheel/tyre (I did for mine) to see if they rub/catch and once you're happy-ish, you can go out and buy them for yourself.
HTH's?
Jalapeño, IISY?
Last edit: 15 years 1 month ago by maverick.
  • p1ngu32
15 years 1 month ago #24020 by p1ngu32
Replied by p1ngu32 on topic Re: 235 75 15 tyres......
I have 30x9.5 15 Malatesta Kobra which a tiny bit bigger and they fit perfect with 7 x 15 modulars -7 offset and no spacers. i had to trim the front edge of the front bumper slightly and remove the front part of the wheel arch liner, so i could still steer when the tyre is well up in the arch during articulation. They are no where near the inner arches or chassis. With standard wheels and spacers the tyre will stick out a little bit further and will need a little more arch trimming. The only issue you might find is your gearing will be way off, i found it bad enough on the 215's having to attack everything at speed so i didnt stall.
[IMG
Wheels are from here www.tyresdirectuk.co.uk/xcart/product.ph...16757&cat=257&page=1
  • zuki andy
15 years 1 month ago - 15 years 1 month ago #24022 by zuki andy
Replied by zuki andy on topic Re: 235 75 15 tyres......
Would have been 265/75 r16 if they measured 32 inches across.
Im currently runing 205/80 r16 on gv rims, their about 29 inches across.r Just got a 2" body lift on so had to trim front bumper and arches a little at bottom.
Last edit: 15 years 1 month ago by zuki andy.
  • srcars
15 years 1 month ago #24031 by srcars
Replied by srcars on topic Re: 235 75 15 tyres......
I am running 235 75 15s MTs and had to trim the front arches on the lower corners to allow for steering lock.
That was fine for on road along with my 3" lift until I went off road. I was getting enough rubbing in the front arches to pull the inner liner fixings out and had to be carefull the rest of the day. I then fitted the 2" body lift I had in the garage and spot on now. No rubbing at all in the rear.
Time to create page: 0.088 seconds
