off road missalignment bushes bearings bush polybu
- myers647
18 Oct 2011 19:14 - 18 Oct 2011 19:15 #23980
by myers647
off road missalignment bushes bearings bush polybu was created by myers647
No eBay APP ID and/or Cert ID defined in Kunena configurationH i wat do you reckon to these. EBAY Item number:
Last edit: 18 Oct 2011 19:15 by mlines.
18 Oct 2011 19:21 #23982
Replied by mlines on topic Re: off road missalignment bushes bearings bush polybu
That would be a very rough and noisy ride!
Also, as the bolt is held in a U-Bracket, the actual flex would be minimal before the arm hits the edge of the U-Bracket. I can happily flex my rubber ones to the point where the arm/bush case hits the U-Bracket.
You would also have to do some work on the Panhard rod as well, because that holds everything in place.
Looks like a bodge mod to me.
- p1ngu32
18 Oct 2011 19:27 #23984
by p1ngu32
Replied by p1ngu32 on topic Re: off road missalignment bushes bearings bush polybu
reading his ad it doesnt sound like he's tried them properly himself! Not even sure if the m20 bolts will fit. How long is that likely to last once its full of mud!
- myers647
18 Oct 2011 19:39 #23986
by myers647
Replied by myers647 on topic Re: off road missalignment bushes bearings bush polybu
Yes it dosn't sound like he's tried and tested them to me either. I just though id post it in case someone was interested il stick to rubber bushes myself.
thanks
thanks
- bluejimny
18 Oct 2011 20:01 #23987
by bluejimny
Replied by bluejimny on topic Re: off road missalignment bushes bearings bush polybu
now that would be a rough ride, probably would only last one off-roading session before the shit gets into the bearing itself
and all above comments!
- g187eev
20 Oct 2011 16:29 - 20 Oct 2011 16:31 #24120
by g187eev
Replied by g187eev on topic Re: off road missalignment bushes bearings bush polybu
I saw those earlier today...
Blimey... oh dear...
Last edit: 20 Oct 2011 16:31 by g187eev.
Time to create page: 0.172 seconds
