Leaking from rear wheel- but not the wheel bearing
- mcjimny
16 Oct 2011 10:34 - 16 Oct 2011 10:35 #23758
by mcjimny
Leaking from rear wheel- but not the wheel bearing was created by mcjimny
I've noticed in the last couple of days that i've got a small amount of oil on the inside of the o/s rear wheel. I took the wheel and drum off earlier and it is only a small amount and coming from the shaft/axle area.
I replaced both rear bearings and i've done less than 800miles since doing so. Is it the axle seal not seated correctly?
There's no play at all in the bearing and no noises related to a shot bearing.
Last edit: 16 Oct 2011 10:35 by mcjimny.
- Dunkspeed
16 Oct 2011 15:32 #23772
by Dunkspeed
Replied by Dunkspeed on topic Re: Leaking from rear wheel- but not the wheel bearing
Its not just leftover oil from changing the bearings is it?
- mcjimny
16 Oct 2011 16:09 #23781
by mcjimny
Replied by mcjimny on topic Re: Leaking from rear wheel- but not the wheel bearing
It does look a little too much to be that, i've cleaned it all up and will see if it keeps happening.
Time to create page: 0.502 seconds
