Stuck transfer box lever????
- ajs850
14 Oct 2011 11:32 #23659
by ajs850
Stuck transfer box lever???? was created by ajs850
HI Just go a jimny havin a few teething problems
The transfer box lever is stuck in 2H ive took the lever out managed to free it up came back to it today moved it out of the garage and its stuck fast again any ideas please
The transfer box is an off road armoury 7 to 1 ratio i think???
Thanks
Andrew
Thanks
Andrew
- g187eev
14 Oct 2011 12:00 #23662
by g187eev
Replied by g187eev on topic Re: Stuck transfer box lever????
Sounds like you need to alight both of your selectors proprly before re-fitting the lever...
Take the lever out and look down in the hole, you must alighn both the selectors to the front before re-fitting the lever... this can be done with either the lever itself or a large screwdriver....
RB
RB
- ajs850
14 Oct 2011 13:18 #23665
by ajs850
Replied by ajs850 on topic Re: Stuck transfer box lever????
Cheers for that will have ago in the morning
Thanks
Andrew
Thanks
Andrew
- ajs850
15 Oct 2011 11:58 #23694
by ajs850
Aligned the selectors this morning and worked brilliantly but after a quick drive it just locks again and I have to remove the lever and repeat! There seems to be alot of play in the lever itself could it be worn?
- Dunkspeed
15 Oct 2011 13:10 #23696
by Dunkspeed
Replied by Dunkspeed on topic Re: Stuck transfer box lever????
I dunno if its any help but brand new Jimnys would do this sometimes (up to 30ish miles)
Our solution at the dealer was to drive it up to 4000 revs in 1st gear, dip the clutch select reverse and lt the clutch up quickly.
It would violently bring you to a halt but it always worked! :laugh:
Was told to me by a Suzuki employee on a course, shhh!
- rjd1
15 Oct 2011 13:41 #23698
by rjd1
Replied by rjd1 on topic Re: Stuck transfer box lever????
are you kiddin was that a serious answer hope no 1 try`s that
Time to create page: 0.198 seconds
