c b radio
  • russell
13 Oct 2011 17:20 #23618 by russell
c b radio was created by russell
hello i have recently fitted a c b radio to my x reg jimny im getting really bad s w r readings and really poor out put and reception dose any one know why this may be iv tryed a few radios in the car but all read the same on a s w r meter witch says to me its the antena witch is mounted on the boot lid but i get very similar readins with a mag mount and advice will be very much apreciated thanks
  • VAXXi
13 Oct 2011 18:05 #23626 by VAXXi
Replied by VAXXi on topic Re: c b radio
You get high SWRs with a mag mount ? those are pretty much plug & play, other than adjusting the antenna length you don't have to do much with them. Is the antenna cable ok ? where did you place the mag mount ?
  • russell
13 Oct 2011 18:13 #23627 by russell
Replied by russell on topic Re: c b radio
yea even with the mag mount witch i had placed on the roof farily central, the coax on the fixed mount on the tailgate is brand new and the mag tests ok with a mulit meter i was wondering if the swr meter could be faulty or the cb its self but i cant see how the cb would effect the swr/ iv seen alot of jimnys with antenas on the spare wheel carrier as mine is but i was wondering if maybe i had to run a seprate earth wire to the antena if the boot hindges were plastic bushed? im really just wondering if its a common thing to be honest? its got me a little stumped
  • p1ngu32
13 Oct 2011 18:15 #23628 by p1ngu32
Replied by p1ngu32 on topic Re: c b radio
Where on the bootlid do you have it mounted? if the antenna is too close to other metal it can give high readings. As vaxxi says though it should work on the mag mount. Are is it any better in the higher channels or lower channels?
  • russell
13 Oct 2011 18:19 #23629 by russell
its pretty simalar across the board its right over in the red on the swr meter its mounted of one of the spare wheel studs with a mogulater type antena iv used a very simalar set up before and it worked well. its the same reading both with mag and fixed antena
  • p1ngu32
13 Oct 2011 18:29 #23631 by p1ngu32
You should have a good groundplane there so it shouldnt be that, its probably the cable or the swr meter, i know my meter is a pain, it needs to be totally level to read correctly, i have my aerial right in the middle of my roof and get an swr of 1 - 1.5 right across all channels. are you testing this well away from any buildings or other sources of interference? shouldnt usually cause a problem but can do.
Time to create page: 0.257 seconds
