CHECK ENGINE
  • ajs850
13 Oct 2011 16:58 #23611 by ajs850
CHECK ENGINE was created by ajs850
HI this has jus come on, on my dashboard "CHECK ENGINE" Does any one have any ideas?
Is it serious?
Thanks
Andrew
  • VAXXi
13 Oct 2011 18:02 - 13 Oct 2011 18:02 #23625 by VAXXi
Replied by VAXXi on topic Re: CHECK ENGINE
Oh come on, it's not that difficult to use the search, is it ? either buy a code scanner which plugs into the OBD-II port and read the codes, or use the jumper method to read the error code:
[IMG
[IMG
Last edit: 13 Oct 2011 18:02 by VAXXi.
13 Oct 2011 18:34 #23632 by mlines
Replied by mlines on topic CHECK ENGINE
Its only serious if you "check engine" and its not there ;-)
Which model do you have as you can get the early ones to flash the code at you.
-- Sent from my HP TouchPad using Communities
  • ajs850
14 Oct 2011 05:53 #23644 by ajs850
Replied by ajs850 on topic Re: CHECK ENGINE
The car is on a w reg but its had a new engine in it not sure what type only got it last night off robs brother at off road armoury pleased with the rest of the truck just need to get it that light out!
Andrew
14 Oct 2011 07:10 #23648 by mlines
Replied by mlines on topic Re: CHECK ENGINE
If its a W reg then the method shown above by Vaxxi will get the code to flash out on the syste, we can then take it forward from there.
  • vitara_mad
14 Oct 2011 08:23 #23650 by vitara_mad
Replied by vitara_mad on topic Re: CHECK ENGINE
here you go works a treat
www.rhinopower.org/diag/cel.html
Time to create page: 0.195 seconds
