Where is the starter motor is on a Jimny M13A!
  • vitara_mad
14 Oct 2011 08:20 #23649 by vitara_mad
srcars wrote: As above can be a PITA to get at. I can tell you the bottom bolt requires a 12mm socket and has with a earth strap attached. The top fixing is the real pain to get at, It is a nut and bolt 12mm bolt head with a 13mm nut. Once you get your fingers on them and work out the knack its not to bad.
sounds like you describing the g13b ????
the starter bolts thread into the starter on the m13a & not hard to get bolts out its just getting starter out after the bolts are out thats the hard part on them
  • srcars
14 Oct 2011 09:13 #23652 by srcars
:blush: Opps, your correct, Forget my advise. I blame my age ;)
13 Feb 2024 14:43 #254259 by hansaplast26
I wanted to take mine out, but the bolts are tightened to the extreme ;-(. what are the torque specs for these two 14mm bolts that hold the starter motor ?
13 Feb 2024 16:35 #254262 by Roger Fairclough
Long long ago I was asked to remove the starter motor from a Renault 16. First instruction in the manual.
Take the engine out.
I managed to do it without removing the engine.
It took me 71/2 hours.
Roger
14 Feb 2024 07:36 #254290 by yakuza
Suzuki stood back and looked at the engine and thought "Where is the most dirty, inaccessible place we can mount the Starter motor where it will get dunked when wading and then fail at the most inconvenient moment"
Therefore it is at the back of the engine, under the inlet manifold and only accessible from underneath, reaching up a full arms length feeling for the blinb bolt on the top whilst the dirt falls in your eyes.
Have fun.
You could also remove the inlet manifold, but thats just as hard.
martin
I think it is easier to remove the intake.
That is mostly just work and not so much pain.
Better to take the 40 minutes of intake plugs and bolts and brackets and save an hour or two of fiddling with it in the way of everything.
Also for changing the clutch or swapping the engine.
I tried to insert my new engine with everything on it but no, half way in I just gave in and removed the intake again so i could more easily access the bolts at the starter and around the gearbox/engine flange.
But note that I do not have a lift and work mostly down the bonnet or lying on the floor.
If you have a lift and can stand under the car it might be less time to access from below.
  • rogerzilla
14 Feb 2024 11:19 #254301 by rogerzilla
If you have the intake off, you might as well do the thermostat.
Time to create page: 0.262 seconds
