Not a cage but.....
21 Feb 2010 18:45 - 21 Feb 2010 18:46 #2403
Replied by mlines on topic Re:Not a cage but.....
Yes, any full cage would need triangulation inside the car otherise it just collapses like any open ended carton would if pushed on the side.
Mine has a diagonal inside the car which bolts through the roof onto the external cage. However if I remember correctly it does not bolt through to the chassis below but goes to some spreader plates on the floor (it was fitted when I bought it). If it went to the chassis it would create an interesting problem where the car body becomes rigidly attached to the chassis rather than "floating" on the body rubbers. As it is my body is effectively attached through to the chassis by the roof bolts to the cage! There is still some movement between the body and the cage as the previous owner fitted small rubbers (door stops!) between the cage and the body and I can hear it move sometimes!
Last edit: 21 Feb 2010 18:46 by mlines.
Time to create page: 0.156 seconds
