The water tank in my Jimny empties suddenly
- Lamelasp
09 Oct 2011 21:41 #23390
by Lamelasp
The water tank in my Jimny empties suddenly was created by Lamelasp
Hi, I'm writing this just in case any of you have an idea so I can fix my problem. I own a Jimny 2008 automatic. Since its last service a month ago, I listen a sound of gurgling water in the passanger side, like it comes from the a/c, and for some reason, suddenly the washer water tank empties.
I took the vehicle to maintenance and they did an a/c diagnostic, said everything was ok and gave no importance to the fact of the washer tank getting empty suddenly. My brother decided to go and test the Jimny with the washer tank empty and after one hour in the road, the a/c stopped working.
Any idea would be welcomed!
P.D. I live in a Caribbean island and the regular temperature is 38C, lots of rain and mud.
10 Oct 2011 05:48 #23396
Replied by mlines on topic The water tank in my Jimny empties suddenly
I hope you don't mind me asking, you not mixing up the radiator header tank and the screen wash bottle are you?
-- Sent from my HP TouchPad using Communities
- ZookFastback
10 Oct 2011 06:36 #23400
by ZookFastback
Bugga, that's what I was thinking
Replied by ZookFastback on topic Re: The water tank in my Jimny empties suddenly
mlines wrote: I hope you don't mind me asking, you not mixing up the radiator header tank and the screen wash bottle are you?
- daniel
10 Oct 2011 07:10 #23401
by daniel
Replied by daniel on topic Re: The water tank in my Jimny empties suddenly
i had this gurgeling sound in a previous car (not a jimny ) turned out it was the heater coor inside the dash board , when not completely full u can hear water in there sloshing around , i would look at your cooling system first .
- Lamelasp
10 Oct 2011 21:40 #23463
by Lamelasp
Replied by Lamelasp on topic Re: The water tank in my Jimny empties suddenly
Ja!, well ... this is my fisrt car ... and my english is not so great .. I'm talking about the screen wash bottle, sorry for the confusion :blush:
- toms79
11 Oct 2011 03:43 #23464
by toms79
Replied by toms79 on topic Re: The water tank in my Jimny empties suddenly
The same error with my jim. When I leave it with rear end lower, screenwash water leaks thru rear window washer noozle. doeasn't happen when on level ground or front end facng down. Considering to cancel the rear washer since it is useless anyway, but not sure. may be to rise it up a little - add noozle directly to wiper.
Time to create page: 0.337 seconds
