Clutch adjustment
  • Back in Black
07 Oct 2011 15:27 #23212 by Back in Black
Clutch adjustment was created by Back in Black
I have just had my clutch replaced, which is nice.
However, I have gone from one extreme to another - worn clutch used the last couple of inches of travel to go from biting to fully engaged, now I have only the first inch of pedal movement to play with, it feels like an on/off switch!!
Is it possible to adjust the length of travel between fully in and fully out, at either the pedal or clutch end? Or is there something wrong? Either me or the clutch.
07 Oct 2011 15:57 #23215 by mlines
Replied by mlines on topic Re: Clutch adjustment
There is an adjuster on the cable where it attaches to the clutch arm underneath the car.
  • dirtydogz
07 Oct 2011 16:05 #23218 by dirtydogz
  • Back in Black
07 Oct 2011 17:36 #23232 by Back in Black
Replied by Back in Black on topic Re: Clutch adjustment
Brilliant thank you - I'll try searching harder next time. The link is spot on for what I needed.
  • dirtydogz
07 Oct 2011 17:43 - 07 Oct 2011 17:44 #23233 by dirtydogz
Replied by dirtydogz on topic Re: Clutch adjustment
That's ok mate we are here to help.
Last edit: 07 Oct 2011 17:44 by dirtydogz.
  • Back in Black
09 Oct 2011 09:06 #23311 by Back in Black
I've followed the clutch adjustment thread and altered the clutch pedal feel - a lot better now. It's more progressive (need to drive around a bit and tweak some).
Like an idiot though, I had the cover off, made an adjustment and went for a quick spin, came back to tweak again and drove over the cover!! Doh. I've stuck it back together but I will now need to visit Suzuki to try and get a replacement, im sure itll come off and i don't want muck getting in.
Thanks for the info, it's more driveable now.
Time to create page: 0.182 seconds
