Re: Manual or automatic gearbox
  • TomDK
20 Sep 2011 20:38 #22219 by TomDK
Replied by TomDK on topic Re: Manual or automatic gearbox
Great thanks, almost similar to my old LC :-)
Already come to love this forum, all these nice people, all this knowledge.. excellent :-)
  • X-Eng Simon
20 Sep 2011 21:10 #22221 by X-Eng Simon
Replied by X-Eng Simon on topic Re: Manual or automatic gearbox
No eBay APP ID and/or Cert ID defined in Kunena configurationThe cooler I used was about this size, but half the thickness. The size was important for the motorcycle fan. Go for as many 'rows' as possible as it increases the flow.
The fittings want to be 3/8 BSP or 1/2 BSP otherwise they will restrict the flow.
Si
21 Sep 2011 14:35 #22273 by Obarno
You're right Facade - you can switch the overdrive off and on as you want. Its a good thing to switch off if you are driving on hilly roads as it stops the box from continually changing down and back up again.
It also has a torque converter lock up which in effect gives a drive with no slippage.
If you start with the selector in position 2 , it will start in first and then change to 2nd so for snow you just have to be a bit careful.
  • rogerzilla
19 Sep 2023 13:16 - 19 Sep 2023 13:17 #250892 by rogerzilla
Replied by rogerzilla on topic Re: Manual or automatic gearbox
Old thread I know, but having had manual and auto Gen 3 Jimnys, the 4 speed auto (2012 car) is about as good and inoffensive as an auto gets.  It can be a bit reluctant to kick down without a good shove, but that's better than my Mazda 3, which kicks down at the drop of a hat and needs a really light right foot for smooth driving.
I'd rather drive a manual car but the Jimny auto really is a good one.  The fuel consumption penalty over a manual is quite small - more like 3-4% than the 10% from the Mazda SkyActiv-Drive!
The ATF in the Jimny is still bright red.  No sign of leaks but I did have to top it up with about half a litre of Dexron III.  I suppose some evaporates in 11 years.
Last edit: 19 Sep 2023 13:17 by rogerzilla.
20 Sep 2023 14:10 #250915 by Gadget
Interesting Obarno. Looking into why my auto sticks in 3rd until well warmed up. About to have the g'box oil changed as I have read that might do the trick, but also understand there may be a sensor that might need kicking!
Thoughts? Is it a common problem? Is there a simple solution (is changing the oil the standard fix?)
Cheers
That's normal behaviour for the auto box from new, on the gen4 models too. None of them will lock up in cold weather until the fluid has warmed up a bit.
20 Sep 2023 14:31 #250918 by 300bhpton
Cheers
I don't think it is about gearbox oil. It is about engine emissions and wanting to warm the engine up quicker by running at higher revs.
Time to create page: 0.166 seconds
