sj410 or sj413 gearbox can it be used on a jimny?
- tonybjimny
19 Sep 2011 16:16 #22138
by tonybjimny
sj410 or sj413 gearbox can it be used on a jimny? was created by tonybjimny
Hi has anybody fitted an SJ gearbox to a jimny.or seen talk discusion on here or other sites.
Thanks for any help.
tonyb
tonyb
- darthloachie
19 Sep 2011 19:19 - 19 Sep 2011 19:20 #22148
by darthloachie
Replied by darthloachie on topic Re: sj410 or sj413 gearbox can it be used on a jimny?
yep a 410 with 413 gears is the basis of a rocklobster
most of the jimny specialists do fitting kits/guards to fit one to your jimny
you will also need a sj413 front prop for the rear
Last edit: 19 Sep 2011 19:20 by darthloachie.
20 Sep 2011 05:56 #22158
Replied by mlines on topic Re: sj410 or sj413 gearbox can it be used on a jimny?
I think Darthloachie has got mixed up? You asked about gearboxes and he replied about transfer boxes.
The early Jimnys have G13B engines which are the same as SJs, therefore you can fit the gearbox as far as I am aware. The later Jimnys have M13A series engines and I don't believe the gearboxes fit.
The following user(s) said Thank You: tonybjimny
- darthloachie
20 Sep 2011 10:26 #22166
by darthloachie
must start reading the question properly :blush:
- X-Eng Simon
20 Sep 2011 11:59 #22171
by X-Eng Simon
Replied by X-Eng Simon on topic Re: sj410 or sj413 gearbox can it be used on a jimny?
Martin, I'm not convinced!
As far as I know, a 1.6 Vit engine will bolt up to a 413 gearbox without an adaptor - though you may have to drill out the odd hole and find a 'thin' starter motor. It will only attach to a 410 gearbox with an adaptor plate AFAIK.
It may be that the 410 box is the same as a Jimny G series??? but the 413 is much less likely to fit without an adaptor.
Why don't you ring & ask Rhino Ray. He has a selection of adaptor plates which are reasonably priced and will have done this at some point. He's known the answer to everything I've asked off the top of his head!
Si
Si
- vitara_mad
20 Sep 2011 12:04 - 20 Sep 2011 12:07 #22172
by vitara_mad
Replied by vitara_mad on topic Re: sj410 or sj413 gearbox can it be used on a jimny?
the adaptor plate ive just sold to tony was taken off a sj that had a 1.6 vit engine & 413/sammy gearbox so i presume it should fit a 413 box to the baleno engine
Last edit: 20 Sep 2011 12:07 by vitara_mad.
Time to create page: 0.216 seconds
