Stearing Dumper
03 Sep 2011 10:22 - 03 Sep 2011 11:29 #21250 by MigCooper
Stearing Dumper was created by MigCooper
I got myself a steering dumper (jimnybits) pro comp one.
I'm not quite sure where the 2 sides bolt on.
Anyone as some pictures they could share?
Thanks B)
Snorkel and plenty of rust to be treated :)
Last edit: 03 Sep 2011 11:29 by MigCooper.
03 Sep 2011 13:26 #21258 by Halford
Replied by Halford on topic Re: Stearing Dumper
Hi Miguel
check out Nobbys Jimny
  • dirtydogz
03 Sep 2011 13:26 - 03 Sep 2011 16:05 #21259 by dirtydogz
Replied by dirtydogz on topic Re: Stearing Dumper
This how l fitted my steering damper.
Attachment DSCF1404_2011-09-03.JPG not found
Attachment DSCF1406_2011-09-03.JPG not found
Attachment DSCF1405_2011-09-03.JPG not found
Or the large ubolt and bracket might bolt to the axle and the steering rod bracket will bolt facing the axle.
Looking at the damper on jimnybits you could drill the top hole on the towing bracket and fix the damper to that and not use the large ubolt bracket.
Attachment DSCF1533.JPG not found
Like this.
Attachment 24.jpg not found
Hope this helps.
Dirtydogz
Last edit: 03 Sep 2011 16:05 by dirtydogz.
  • supergaz
03 Sep 2011 16:55 - 03 Sep 2011 16:58 #21267 by supergaz
Replied by supergaz on topic Re: Stearing Dumper
I have instructions/ pictures written by Rus from jimnybits, I will message him if I can put the file up on here, maybe he will be reading this? and help out.
If not I can e-mail you his instructions.
The jimnybits damper bolts to the back of the axle and then to the rear steering link.
Last edit: 03 Sep 2011 16:58 by supergaz.
03 Sep 2011 21:57 #21274 by MigCooper
Replied by MigCooper on topic Re: Stearing Dumper
that would be great Supergaz.
I was trying the method that uses the tow point, but the shock wont fit as the pitman arm is in the way.
I think I can see how it will fit now but the help will still be appreciated... thanks :)
  • dirtydogz
04 Sep 2011 09:15 - 04 Sep 2011 09:31 #21280 by dirtydogz
Attachment IMG_0051.JPG not found
How to fit pro comp steering damper this one is on a SJ413 but will fit the same way.
Attachment dampner.jpg not found
hope this helps.
Linkhttp://www.suzukiclubuk.co.uk/phpBB3/phpBB3/viewtopic.php?f=23&t=2412
Last edit: 04 Sep 2011 09:31 by dirtydogz.
Time to create page: 0.558 seconds
