4x4 Not working
03 Feb 2010 13:03 #2157 by mlines
Replied by mlines on topic Re:4x4 Not working
Fixed hubs are an early feature, manual free wheeling hubs were an extra cost option early on.
You can use the fixed hub units but it gives you fewer "get me home" options when you break something. Manual free wheeling hubs give you the opportunity to disconnect the front transmission if a problem occurs. With fixed hubs your CVs, diff and front prop all continue to rotate at all times.
  • Garry
03 Feb 2010 16:07 - 03 Feb 2010 18:54 #2158 by Garry
Replied by Garry on topic Re:4x4 Not working
they had two types of free wheeling hubs, the standard ones, and the aisin ones i have
Last edit: 03 Feb 2010 18:54 by Garry.
11 Mar 2024 18:52 #255012 by REEDD
Replied by REEDD on topic 4x4 Not working
Hi Guys and Girls,
I've got an issue with my 4 wheel drive not working and alarmingly a noise coming from what I believe to be the transfer box but I could be wrong.
What I know is...
There is a humm/grind above 28mph and severe between 28 and 40, it's intermittent.
A garage has had it on the ramp and says the 4 wheel drive system isn't engaging and that the front prop doesn't spin, however when you press the buttons I can hear the motor in the transfer box doing something and all sounds positive.
The Jimny is a 60 plate with 102,000 miles on it and it seems to have been looked after.
The garage I took it to believes that it is trying to put itself into 4 wheel drive low as your driving but this doesn't make sense to me (I'm in engineering but by no means a mechanic or have any good electrical knowledge).
This garage recommended I check some solenoids and failing that change the transfer box which I think personally may solve the problem as it seems an obvious place for the problem.
I'm told by another garage that the rear prop had seized and this was replaced at dealers expense. He also said the hum might have been the tyres or a wheel bearing, but I'm certain that isn't the case.
Does anyone have any ideas of what to look at?
Thanks in advance
11 Mar 2024 20:27 #255021 by Lambert
Replied by Lambert on topic 4x4 Not working
There's a lot more information in the information section in the top banner but it's likely that you have a hub not doing it's thing properly in the front axle. I'd need serious evidence to go swapping the transfer box first off.
