Bought some steelies...
  • InverChuck
02 Sep 2011 16:29 - 02 Sep 2011 16:30 #21215 by InverChuck
Bought some steelies... was created by InverChuck
from flea bay, advertised as 15", turns out to be 16 x 6.5... :unsure:
Can I still use these on my 08 Jimny without modding anything? If so what size tyres would I need?
Tkx
Last edit: 02 Sep 2011 16:30 by InverChuck. Reason: Remove failed attachment link.
  • little jimny
02 Sep 2011 17:35 #21218 by little jimny
Replied by little jimny on topic Re: Bought some steelies...
You could try the following sizes to keep within 2.5% of the standard 205/70/15;
Tyre code Diameter Circumference Difference
205/60 R16 652 mm 2048 mm -2.34 %
215/60 R16 664 mm 2086 mm -0.54 %
225/60 R16 676 mm 2124 mm 1.26 %
205/65 R16 673 mm 2114 mm 0.73 %
  • InverChuck
03 Sep 2011 09:29 #21246 by InverChuck
Replied by InverChuck on topic Re: Bought some steelies...
Thanks for the reply, I have just realised I was being dense and had measured the wheels literally to include the lip of the rim..... :blush:
So I guess they are 15 x 6.5 :P
  • ZookFastback
03 Sep 2011 09:51 #21248 by ZookFastback
Replied by ZookFastback on topic Re: Bought some steelies...
Used to be undecided but now you are not so sure? :p
  • mcjimny
03 Sep 2011 10:17 #21249 by mcjimny
Replied by mcjimny on topic Re: Bought some steelies...
The sizes are usually stamped into the lip of the wheel or on the inside. Will have all the info on there.
Time to create page: 0.170 seconds
