Is Jimny T-Case Spline the same as an SJ??
- blitzn
02 Sep 2011 00:38 #21161
by blitzn
Is Jimny T-Case Spline the same as an SJ?? was created by blitzn
Hey,
Can anyone confirm weather the Jimny T-case has the same splines as the SJ T-Cases??
Eg would a Jimny Flange fit a SJ case? i assume they are the same just wanted to hear from someone that knows?
Cheers
Als
Cheers
Als
03 Sep 2011 14:29 #21262
by Obarno
Replied by Obarno on topic Re: Is Jimny T-Case Spline the same as an SJ??
Unfortunately not. The Jimny has bigger diameter shafts so the flanges won't fit a sj transfer case.
