M13A engine into 1999 hardtop ?
  • Gromit
17 Aug 2011 12:24 #20544 by Gromit
M13A engine into 1999 hardtop ? was created by Gromit
Probably been asked before but will the later M13A engine go into an older (1999) hardtop without any major problems as my old SOHC engine is getting tired & leaky ??
17 Aug 2011 14:37 #20552 by facade
AFAIK, the gearbox wont fit, and the engine electrics are different.
  • X-Eng Simon
17 Aug 2011 17:48 #20576 by X-Eng Simon
Replied by X-Eng Simon on topic Re: M13A engine into 1999 hardtop ?
As Facade says - the bell housing is different and will not bolt up to your gearbox.
The electronics side of things is fixable with the likes of Megasquirt.
A simpler and cheaper solution would be to source a Vitara 1.6 engine. You still need an adaptor plate to convert between the two, but the are readily available from the BJ shop, Rhino Ray and others.
Si
  • ypvs jimny 350
17 Aug 2011 20:12 #20594 by ypvs jimny 350
Replied by ypvs jimny 350 on topic Re: M13A engine into 1999 hardtop ?
hi if u put a m13a engine in a jimny that was fitted shoc before will the dvla need to no about it ? and will the tax be same price with engine being twin cam ?:blink:
17 Aug 2011 21:21 - 17 Aug 2011 21:25 #20602 by facade
You are supposed to tell them the engine number of a replacement engine (box on your V5)* , and I guess the new capacity as well: the M13A is slightly larger. :whistle:
This could trigger some official interest, so make sure you can prove it wasn't stolen, or out of a car that should have been destroyed under the scrappage scheme, or whichever insurance category means "crush the lot".
No doubt your insurance company will treat a different engine from original specification as a modification, and if they are not informed too refuse to pay out if you have an accident :S
*Never understood why there is a box to change the chassis/VIN number: you get the new one stamped with the old number and destroy the old one AFAIK. If you put down a chassis number that is already registered the police would be straight round.
Last edit: 17 Aug 2011 21:25 by facade.
