Might be a bit of a stupid question!!
  • hulatt
16 Aug 2011 09:44 #20436 by hulatt
This might be a stupid question..... :blush:
I am pricing up a set of mods and mt tyres in a different size to the originals as a second set. Is a second spare wheel and tyre required in the new mt size? Or can the car be driven in two wheel drive with the standard size spare tyre on the front in the event of an emergency to get us home?
  • adamatdraycott
16 Aug 2011 09:50 #20437 by adamatdraycott
Replied by adamatdraycott on topic Re: Might be a bit of a stupid question!!
You'd no doubt get away with the odd tyre, space savers are commonly slightly smaller than the others.
But for the extra £100 ish you'll have a full set, and your truck will look the part
  • ooky_123
16 Aug 2011 10:33 #20439 by ooky_123
Replied by ooky_123 on topic Re: Might be a bit of a stupid question!!
I personally have the standard wheel / tyre as a spare for the same reason ... If I have a problem, then Ill limp home. If im off road, then Ill just use the tyre as it is... yes it will get ruined, but I only run remoulds so its not going to be megga money.
Also, as I have larger diameter wheels and tyres fitted than standard, it isnt po9ssible without modification to mount a similar sized tyre
16 Aug 2011 11:27 - 16 Aug 2011 11:27 #20449 by maverick
Not me ... i have 16/205/75 all around.... cant see me limping home on a 15" standard road tyre!!
Jalapeño, IISY?
Last edit: 16 Aug 2011 11:27 by maverick. Reason: typo
  • hulatt
16 Aug 2011 14:52 #20460 by hulatt
Replied by hulatt on topic Re: Might be a bit of a stupid question!!
Thanks guys
Was always told not to put different size wheels opposite each other on the same axle with a diff. And thought that on the front, once the hubs are unlocked (in 2wd) then this wouldn't put any strain on the diff.
  • mcjimny
16 Aug 2011 15:26 #20466 by mcjimny
Replied by mcjimny on topic Re: Might be a bit of a stupid question!!
I've heard similiar advice but i've only got a standard steel on the back door with one of my worn at's on it. You could rotate but then it would be on the steering and you would be compensating in the steering.
Unless you are running a massive difference in tyres i can't see it being an issue to limp home. As others have pointed out space savers are different sizes.
Time to create page: 0.320 seconds
