How to get a Power Steering Belt back on ....
- Thank you received: 115
16 Aug 2011 11:21 #20448
by maverick
Jalapeño, IISY?
Replied by maverick on topic Re: How to get a Power Steering Belt back on ....
yes on a Twin Cam (DOHC) ...
There's NO NEED to remove Alternator - just relase the two front studs on the bar that holds the alternator to the engine .. and grasp it from above, wrapping one hand around it and pull up! It does move, honest.
Believe me, I know how horrid it is undo-ing that rear/lower bolt on the alternator, as i had to fit a new alternator recently ... at the time, I seriously considered taking the engine out, fitting the alternator to the engine ... its in a horrid place ... I still have the scars and sh1t/dirt in my eyes!!
i take my radiator out in 10mins .. empty it of water, undo two nuts/bolts at the top (attaches to the straight bars), remove the Simon (4 or 5 studs), remove Hose-clips .. pull it out .. simples!
Jalapeño, IISY?
- Mumbo Jimbo
- Visitor
16 Aug 2011 11:50 #20452
by Mumbo Jimbo
Replied by Mumbo Jimbo on topic Re: How to get a Power Steering Belt back on ....
Yep, the alternator will move after removing the tensioner bar at the top held on by 2 studs. It's very tight but it will move, especially with a bit of careful persuasion with a pry bar.
16 Aug 2011 14:19 #20456
by facade
Replied by facade on topic Re: How to get a Power Steering Belt back on ....
I couldn't move mine, the amount of leverage I was using I thought either the alternator case would shatter or the bracket would snap off the block before it moved.
17 Aug 2011 02:52 #20516
by kirkynut
Replied by kirkynut on topic Re: How to get a Power Steering Belt back on ....
You don't need to remove the tensioner or radiator, so no need to drain any coolant.
Just get it on as best you can levering it on with a screwdriver, then use the quick click of the starter method you have used.
This is how I did it.
17 Aug 2011 07:23 #20534
by maverick
Jalapeño, IISY?
YES you 'can' do it without removing the Tensioner - cos thats what we did on the mountain top ... but we failed on four attempts to ge the belt on properly, and gave up when it was on 75% of the way, but that cut/wore-off the remained belt ... so this is why i did it properley yesterday.
Also, whoever did the P/S Belt last time 'foolishly' thought it wa sa good idea to tighten-up the Nyloc nut so it would move at all - which i suspect is why we couldnt do it on Sunday.
My tensioner Nyloc now holds on the tensioner but still allows it to move ...
Jalapeño, IISY?
- b81
- Visitor
02 May 2012 22:12 #39198
by b81
Replied by b81 on topic Re: How to get a Power Steering Belt back on ....
Thank you for your amazing contribution. Your article saved me hours if not days of figuring things out, and probably money. Thank you !
07 May 2012 06:45 - 07 May 2012 06:45 #39449
by saxj
Replied by saxj on topic Re: How to get a Power Steering Belt back on ....
I've replaced the belts and tensioner on my VVT without removing the radiator, but I do have small hands.
After a bit of frustration, I was seriously contemplating removing the radiator though.
Last edit: 07 May 2012 06:45 by saxj. Reason: grammar
Time to create page: 0.170 seconds
