Rear wheel cylinders / slave cylinder ?
  • doncarlyon
13 Aug 2011 15:38 #20290 by doncarlyon
Rear wheel cylinders / slave cylinder ? was created by doncarlyon
Seal is splint on one of mine and when removing it one of the bolts snapped, so need a new one.
Anyone know the best place to try?
13 Aug 2011 17:40 #20301 by facade
Suzuki agent (if you have the money)
Motor factors
Scrap yard (likely same on the wagon/liana/swift etc)
eBay
Personally, I'd use my local motorfactors, then I can take it back when it starts leaking after 3 months.
  • myers647
13 Aug 2011 17:42 #20302 by myers647
Replied by myers647 on topic Re: Rear wheel cylinders / slave cylinder ?
Hi
Mate I have one lying around some where il have a look for it tomorrow if you wan it. Just pay for the P&P. It has been used but it's in good working order. Or you can gr one from most car spares shop for about £14 so not a expensive fix.
James
  • doncarlyon
13 Aug 2011 18:00 #20307 by doncarlyon
Replied by doncarlyon on topic Re: Rear wheel cylinders / slave cylinder ?
Could do with one asap really... will try some local motor factors and see what i find.
A mate is going to sort the brake pipe, so hopefully be back on the road soon.
  • mcjimny
13 Aug 2011 21:34 #20317 by mcjimny
Replied by mcjimny on topic Re: Rear wheel cylinders / slave cylinder ?
My local factors can get them next day and they're dirt cheap, i'd not even consider the main stealer.
  • doncarlyon
15 Aug 2011 07:00 #20366 by doncarlyon
Local factors doesnt stock DOT3 fluid, am i ok to use DOT4?
Time to create page: 0.195 seconds
