Extra Lift ... An idea
28 Jan 2010 08:05 #2064 by Obarno
Replied by Obarno on topic Re:Extra Lift ... An idea
I've just gone thru something similar adding B4V spring spacers which work fine. Just compress the original springs, remove the original packing at the top of the spring and insert the spacer. For the shocks I used B4V shock extensions on the front and Martin sells extenders for the rear which has the effect of moving the shock away from the spring. Thus you don't need to buy new shocks.
I found that the original castor correction bushes (KAP) didn't work so well with the new lift so I used new front arms from Off Road Armoury, and put the original castor correction bushes in the rear arms to try and correct the diff angle.
  • ooky_123
03 Feb 2010 10:42 #2150 by ooky_123
Replied by ooky_123 on topic Re:Extra Lift ... An idea
Im in Andover, Hampshire.
Parents in South Wales ... Or anywhere in between !!
Time to create page: 0.425 seconds
