Clutch Cable
- Cocopolo
15 years 3 months ago #20109
by Cocopolo
Clutch Cable was created by Cocopolo
Last week i had to change for the 4th time in 6 years the clutch cable on my Jimny, as the left pedal movement was very hard and harsh ...
Did anyone of you found a trick to avoid the clutch cable become so rough after regular use in muddy tracks?
I tried the trick mentioned in this link, but it only delayed the problem of few weeks ...
www.bigjimny.com/images/documents/Washing_the_Clutch.pdf
Thanks
Sandro
Thanks
Sandro
15 years 3 months ago #20125
by maverick
Jalapeño, IISY?
Replied by maverick on topic Re: Clutch Cable
I've had my Jimny now for 6yrs and never had to replace a clutch cable ...
Tip: Get your left foot off the pedal more!!
Jalapeño, IISY?
- vitara_mad
15 years 3 months ago #20126
by vitara_mad
Replied by vitara_mad on topic Re: Clutch Cable
i had my jimny 12 months & i fitted a new cable when i bought it as it was very stiff & it lasted about 8 months before a had to fit another
my bro bought his jimny couple of months before me & he still got it & never had any probs with the cable its still very light
15 years 3 months ago #20130
by facade
Replied by facade on topic Re: Clutch Cable
I suspect you are using the £50 copy of the clutch cable, rather than the £100+ genuine Suzuki part.
Aftermarket stuff is usually cheaper for a reason
Also the cable is lined and doesn't need lubrication, extra grease tends to hold grit and work it into the outer cable.
- Cocopolo
15 years 3 months ago - 15 years 3 months ago #20131
by Cocopolo
Replied by Cocopolo on topic Re: Clutch Cable
I use always suzuki original spares ... as i learnt that they last much more than aftermarket ... but clutch cables (and sometimes rear wheel bearings) ... do not last long anyway...
... thanks for the advices ...
Last edit: 15 years 3 months ago by Cocopolo.
- Nelson83
15 years 3 months ago #20142
by Nelson83
I replaced my OEM clutch cable with a genuine suzuki one about a month ago after it snapped - there was a 3 week as there werent any in any of the european warehouse stocks so one had to be sent for from Japan - total cost £56
Replied by Nelson83 on topic Re: Clutch Cable
facade wrote: I suspect you are using the £50 copy of the clutch cable, rather than the £100+ genuine Suzuki part.
