Panhard rods - lengthening.
- ooky_123
10 Aug 2011 15:48 #20134
by ooky_123
Replied by ooky_123 on topic Re: Panhard rods - lengthening.
standard pannard rods are very weak .. you can bend one across your knee.
The easiest way of re-enforcing them is to weld angle iron across the length.
but as has been said, the welds need to be spot on and you can harden the bar locally causing fatigue spots.
I like the CDS option
- mark1971
10 Aug 2011 18:49 #20146
by mark1971
Replied by mark1971 on topic Re: Panhard rods - lengthening.
I'm getting a spare rod from a mate of a mate so I can have a go without destroying the ones attached to the jimny. If I can suss out the length of the panhard for the 3" lift I might just get hold of some thicker walled tubing and weld the bush eyelets onto the end of it, hopefully making a much stronger solution.
- p1ngu32
10 Aug 2011 19:46 #20152
by p1ngu32
Replied by p1ngu32 on topic Re: Panhard rods - lengthening.
Would it be possible to get tube the size of the bush eyelets and make the whole thing out of that? or is it going to be far too beefy?
- mark1971
11 Aug 2011 04:40 #20160
by mark1971
I need to have a look under the car to see if there are any clearance issues if I'm going to fit a thicker panhard. I think I'm going to go down the solid bar approach and the thicker the better then weld the eyelets on the end, that should create something up to the job. All the pointers you guys have made are appreciated and made me think about safety a bit more, so thumbs up fellas.
- dadam
11 Aug 2011 07:59 #20172
by dadam
Replied by dadam on topic Re: Panhard rods - lengthening.
Zanfi also sells a spacer for the front (the only one i've ever seen actually)
I just mounted my panhards from JimnyBits a few hours ago, the weight difference is huge, the stock ones weight like plastic bars...
But i needed to shorten them at the max to have a good alignement, pretty strange with 3" lift i find...
My steering wheel has moved to keep the wheels in the right position, but it's so logical, and regarding to the degrees it took, i'm now pretty sure there wasn't only approx 3mm to correct!
