Need some advice on kingpin bearings
  • Luke jimny
21 Jan 2010 15:43 #1967 by Luke jimny
Need some advice on kingpin bearings was created by Luke jimny
Hi, i've a 1999 jimny and need to replace the kingpin bearings on both driver and paasenger side.
I've been to my local suzuki dealer but the the price they gave me for both the kingpins and the bearings nearly made me fall over in shock, they were that expensive.
I've looked on ebay for them and found some at a good price but i'm not sure if they are the right ones or if they are just cheap copies.
If anyone can point me in the right direction on where to get some at a good price i'd be most appreciative.
Thanks.
21 Jan 2010 15:57 #1969 by mlines
Umm.....now let me see..?
There is quite a good shop here...
store.bigjimny.com/index.php?act=viewProd&productId=4
I am on good terms with the owner ;)
Being serious for a minute, beware of really cheap ones, unbranded "white box" ones as there are a lot of lower quality Chinese bearings on the market. There are a lot of mid range price ones around, including Chinese ones, that are pretty good. So don't go too cheap.
And of course, I would recommend my own Koyo ones which are the ones Suzuki supply.
  • Luke jimny
21 Jan 2010 16:57 #1976 by Luke jimny
Replied by Luke jimny on topic Re:Need some advice on kingpin bearings
Thank you very much. I will give them a try asap and hopefully everything will go well. Thanks again :)
  • wildfire
21 Jan 2010 18:33 #1978 by wildfire
Replied by wildfire on topic Re:Need some advice on kingpin bearings
The guide that on here is very good for doing the kingpins, i would suggest if you can find one is a 50ml syringe. It allows you to measure the amount of grease your putting in so you dont over pack the joint.
Time to create page: 0.154 seconds
