Wheels, what happened in 05?
- InverChuck
24 Jul 2011 13:06 #19437
by InverChuck
Wheels, what happened in 05? was created by InverChuck
I see adverts for aftermarket wheels labelled 98-05 and 2005 on... so what's the difference?
24 Jul 2011 13:23 #19438
Replied by mlines on topic Re: Wheels, what happened in 05?
They change the diameter of the hub centre by a tiny fraction (107mm to 108.3mm)
Therefore new wheels will fit older cars whilst older wheels are not guarateed to fit newer cars unless the hub centres are large enough.
The following user(s) said Thank You: InverChuck
- FIRSTJIMNY
27 Jul 2011 23:46 #19616
by FIRSTJIMNY
Replied by FIRSTJIMNY on topic Re: Wheels, what happened in 05?
Was there some good reason for that change?
28 Jul 2011 11:12 #19629
by facade
Replied by facade on topic Re: Wheels, what happened in 05?
I think it is to accommodate alloy wheels that mount on the hub ring. There was some problem with the early alloys distorting when the nuts were done up tight.
- adamatdraycott
28 Jul 2011 11:36 #19630
by adamatdraycott
Replied by adamatdraycott on topic Re: Wheels, what happened in 05?
Pretty sure the newer hubs have the Suzuki 'S' on the centre of the hub (in the casting)
I have the 3 spokes that distort... and you have to be very careful and remember to tighten the nuts diagonally to make sure the wheel is pulled on straight
Time to create page: 0.170 seconds
