Problem with jackshafts
  • FIRSTJIMNY
18 Jul 2011 20:12 #19155 by FIRSTJIMNY
Problem with jackshafts was created by FIRSTJIMNY
Went for my MOT. I have a 2001 Jimny (left-hand drive) they said there was a lot of play in the jackshafts.
Service said it was necessary to change 2 of the 3 jackshafts. Wanted a huge amount of money. Why can't the universal joints (I think you guys call them c.v.'s) just be changed to take care of the problem?
I found replacement shafts at Zanfi.it that have c.v.'s at both ends. With this stop the problem? I'm not
familiar with this but don't want to keep buying jackshafts.
Anything you have to share will be appreciated.
19 Jul 2011 04:37 #19159 by mlines
Replied by mlines on topic Re: Problem with jackshafts
We call them Universal Joints as well, the C.V joints are on the front half-shafts.
The later propshafts have changeable U.Js. The earlier ones don't show them as being changeable but I have never looked.
  • FIRSTJIMNY
19 Jul 2011 06:05 #19163 by FIRSTJIMNY
Replied by FIRSTJIMNY on topic Re: Problem with jackshafts
thanks for the help. i have quite a bit of play in the front shaft and a little in the rear. will changing the u joints correct this or does something else need to be done? as you can tell i know little about this kind of thing.
if they aren't changeable does that necessitate changing the whole propshaft?
thanks
  • darthloachie
19 Jul 2011 06:06 #19164 by darthloachie
Replied by darthloachie on topic Re: Problem with jackshafts
Hi
If as Martin says you mean propshafts, you can change just the UJs on the props - you can on my 1999 one as I had one on the front prop done - take the prop to a propshaft/driveline company and they will do it for you (cost about £40 each in the UK)
also check to see if they have grease nipples - pumping some thick grease in may firm them up enough to pass the mot and then you can get them fixed as you can afford
You only really need wide angle uj's if you have a lift over 3" and you can tell by looking at the flanges around the uj to see if there is any contact damage
19 Jul 2011 07:21 #19168 by mlines
Time to create page: 0.402 seconds
