4xfourArt, any feed-back?
- dadam
05 Jul 2011 03:43 #18588
by dadam
Replied by dadam on topic Re: 4xfourArt, any feed-back?
and so what about the fact the rear ones were shorter, now you've mounted them?
Can't you give us some videos of a jimny with the lift kit in action please, cause by searching in english i can't find anything...
- panosd
05 Jul 2011 12:08 #18602
by panosd
Replied by panosd on topic Re: 4xfourArt, any feed-back?
Tommorow after work i will go for a mini route and recorder it. At night i will upload it.
- dadam
09 Jul 2011 23:55 #18768
by dadam
Bump!
- panosd
08 Sep 2011 13:13 #21516
by panosd
I made a small test articulation for the first time after installing the arms and i must say that is better than my previous caster arms.
It is not very good quality but i hope you can understand the travel of the axles.
Soon i will upload a newest one with better resolution.
tinypic.com/player.php?v=dbnn2s&s=7
- Johnniehec
- Thank you received: 56
08 Sep 2011 15:14 #21521
by Johnniehec
If it's the same type of upgrade as "jimny low ratio gearset" then you still have the chain which is supposedly the weakest link in the Jimny transmission.
John.
Replied by Johnniehec on topic Re: 4xfourArt, any feed-back?
noggin wrote: Has anyone seen the 4wd transmission gear or have any experience of them? At 550 euros would it work out cheaper than a rocklobster and do the same thing?
Craig G(Noggin)
John.
- dadam
08 Sep 2011 21:08 #21532
by dadam
thanks panosd for the answer, are still the rear ones shorter than stock?
Time to create page: 0.172 seconds
