idol problems
- daniel
02 Jul 2011 06:27 #18480
by daniel
idol problems was created by daniel
hi , i have a 2000 model jimny ..the idol rpm keeps dropping and almost cuts out when stopped at traffic lights ect..idols between 450 - 900 i changed spark plugs and ignition leads but still the same .. can anyone give me a lead to my next move ?
- Thank you received: 115
02 Jul 2011 07:27 #18485
by maverick
Jalapeño, IISY?
Replied by maverick on topic Re: idol problems
an expert (like Martin) will be along soon ... but I'd be suspecting the Lamda Sensor on the exhaust ...
Ig it is the Lamda, then dont get one from Suzuki, unless your a rich-git, get an 'after-market' one if you can find it - Martin should be able to help there too?
Jalapeño, IISY?
- Sandez
02 Jul 2011 08:05 #18487
by Sandez
I had a similar issue (or the same) with a rough idle, I checked the PCV valve and replaced it as Martin suggested and it seemed to have fixed most of it, its now a LOT less rough at idle (idle doesnt drop like it used to, but still have another problem). It was a $22 (AUD) part.
Check my post here for the symptoms and fixes I tried
Replied by Sandez on topic Re: idol problems
mlines wrote: Grasping at straws but have you looked at the PCV valve (yellow thing on the manifold. If it is gungy/sticky it could give problems.
Remove it and clean it throroughly. Blow throug it and see if it works (you can blow one way and not the other), see if it works smoothly, if not then replace.
- daniel
02 Jul 2011 08:13 #18488
by daniel
Replied by daniel on topic Re: idol problems
ok can u tell me where pcv valve is located , is it on the manifold
? thanx
? thanx
- daniel
02 Jul 2011 22:07 #18503
by daniel
i not sure where pcv valve located i have 2000 model ma , theres nothing yellow on the manifold
- Sandez
03 Jul 2011 07:10 #18506
by Sandez
Top of engine without the plastic cover on it
Mine wasn't yellow either, but was white (now black) but the pic shows where it is. It just pulls out. Make sure there is no gunk visible, if so clean it. Shake it and make sure it rattles, its meant to. Try and blow into it both ways, should only be able to blow into it one way no matter how hard u blow. It can be cleaned (google cleaning pcv valve) but I would suggest replacing it if you have one of the above issues. Also check to see if its not too loose, should sit in the engine nice and firmly (mine didnt before).
Attachment PCV.jpg not found
Time to create page: 0.160 seconds
