water in tappets 13b engine
  • leslie
16 Jun 2011 19:07 #17908 by leslie
water in tappets 13b engine was created by leslie
what could cause water mixing with oil ? changed head gasket pressure tested cyclinder head o k
head skimmed , pressure tested system ok
16 Jun 2011 20:18 #17910 by facade
I had an engine that froze up one winter and cracked the block internally so that an oilway leaked into the water jacket.
The following user(s) said Thank You: leslie
  • DVs-Jimny
16 Jun 2011 21:43 #17912 by DVs-Jimny
Replied by DVs-Jimny on topic Re: water in tappets 13b engine
Cracked block, poor oil and short trips that never warm the engine properly resulting in condensation under the rocker cover, white gunk under the 710 cap...
  • Mr Gringo
17 Jun 2011 13:25 - 17 Jun 2011 17:54 #17940 by Mr Gringo
Replied by Mr Gringo on topic Re: water in tappets 13b engine
Hi.
If this is any help i drive a vauxhall meriva 1.6 petrol (gulp) and its a nightmare for condensation build up in the oil due to the engine is very over cooled on that model. It uses no water but always gets a mayoniase build up on filler cap and tiny droplets in oil. Its a very common fault on them and if i`d have listened to others then i would have done the head gasket miles ago. But its fine and simply because i do very few miles we never ever really give the car a good run as we have a larger car when we go further.
I just change the oil alot more regular than normal. (it happens more over winter which i`m guessing as the car does a short journey plus the heater on full whack to warm the car up)
If you search this subject on google you will find responses.
I would monitor your radiator water level to see if your are actually losing water or if it really is only condensation.
((i`m about to do the head gasket on my Jimny))
Last edit: 17 Jun 2011 17:54 by Mr Gringo.
Time to create page: 0.142 seconds
