Need info on Jimny's (compared to Landy's) - help?
05 Jan 2010 09:45 - 05 Jan 2010 09:45 #1795
Replied by mlines on topic Re:Need info on Jimny's (compared to Landy's) - help?
The trouble is both those Jimnys are not really lightly modified, they are quite comprehensively modified to achieve the simple look.
According to the site, in order to run those tyres the first one has a 6.1 Samurai T-case, front and rear HD axle shafts and CV's. 4.57 R&P's with front and rear ARB airlockers. 1600-16v engine with 2WD Vitara main case. 4 inch D&G suspension kit and a 3 inch bodylift. HD front and rear radius arms with castor correction. As it is a DGTuning built car it is very well built, but took the Gross National Product of a small African country to finance.
The other one is also listed as having an SJ T-case, this time a 4.16 Rocklobster, so again its becoming a more major build. It has a DGTuning plastic bumper behind the winch bar, I cannot see who made the winch bar
Last edit: 05 Jan 2010 09:45 by mlines.
- 300bhpton
05 Jan 2010 13:35 #1797
by 300bhpton
Replied by 300bhpton on topic Re:Need info on Jimny's (compared to Landy's) - help?
I guess that's me all over :lol: always wanting a bit too OTT.
Ok if I was to step it down a bit (at least to begin with).
1. Do you know what make of snorkel is on those Jimny's?
2. Using stock rims, what sort of size tyre can you go to without the need to regear?
2a. What size tyre if retaining stock suspension? And if a small lift was added (say 2") what size tyre then without having to sort out the gearing?
Thanks.
Thanks.
- funkyjimny
- Moderator
- 2004 jimny soft top, factory hardtop, ARB bumper
- Thank you received: 56
05 Jan 2010 13:40 #1798
by funkyjimny
Replied by funkyjimny on topic Re:Need info on Jimny's (compared to Landy's) - help?
stick with 195/15 mud terrains on std rims, theyre slightly taller than standard and will get you further than you think, the snorkels a TJM Airtec one and Martin sells then on here, stock expected soon i believe - i had one on my previous jimny and they fit well and are really tough.
Gary
Gary
05 Jan 2010 13:41 #1799
- ooky_123
05 Jan 2010 13:43 - 05 Jan 2010 13:45 #1800
by ooky_123
Replied by ooky_123 on topic Re:Need info on Jimny's (compared to Landy's) - help?
We run 215rx15 on standard rims (well slightly wider daihatsu rims which equates to a 29" tyre. this needs a 2" suspension lift and very light bumper edge trimming. Some go for trimming the wheel arches completely but we didnt
I believe Martin runs 235x70's although a common swap is to go for Vitara 16" wheels and fit Landrover tyres (but you may need to lift the body too.
We run 215's and to be honest this is about as large as the little 1.3 can cope with on standard gears.
5th gear is rarely used and we frequently drop to Low Box when fording / doing any offroading. Mainly for the control. It would be nice to go lower but then you have to look at swapping TX boxes or ratios
Last edit: 05 Jan 2010 13:45 by ooky_123.
05 Jan 2010 13:50 - 05 Jan 2010 13:54 #1801
Naah, still running Goodyear Wrangler MT/R 235/75 R15 tyres....
...I have everything ready for some nice R16 tyres, except the money
Just when I thought I had the money I seem to have got some new bedroom furniture instead
Last edit: 05 Jan 2010 13:54 by mlines.
Time to create page: 0.569 seconds
