removing internal rear trim and tailgate panels
08 Jun 2011 05:42 #17500 by Halford
Hi all,
just wondered as to whether anyone could offer step by step advice or pics upon removal of internal rear side panels / and internal rear door trim - I'm looking to replace speakers and add fixings to rear door for storage (map pockets etc)
I've already convinced myself I'll snap something and sulk for the rest of the day :unsure:
thanks for any help
  • VAXXi
08 Jun 2011 08:04 #17507 by VAXXi
www.answerbag.com/q_view/1058351
Short story:
- remove rear seat bottom by pulling hard straight up (pull in front, there are two clips there)
- unclip the plastic ornaments which cover the rear seatbelt (between the rear seats, in the middle)
- you have 4 screws on the bottom (still between the rear seats)
- pull the velcro carpeting on the back of the seats, in the corner to expose the screw which holds the L shaped bracket
- now you should be able to remove the rear seats, leaving you with two more screws for the other part of the bracket
- the plastic trim in the rear is held by 2 or 3 screws and lots of plastic clips which will certainly break and will need to be replaced if you don't want to get lots of annoying buzz from the trim :pinch:
  • adamatdraycott
08 Jun 2011 08:14 #17508 by adamatdraycott
Replied by adamatdraycott on topic Re: removing internal rear trim and tailgate panels
I removed the trim to wire my tow bar in and didn't snap any clips... you just have to be careful pulling it off evenly
  • Municipal Waste
08 Jun 2011 13:05 #17512 by Municipal Waste
Replied by Municipal Waste on topic Re: removing internal rear trim and tailgate panels
Two of the plastic clips in the door jam on my newer model can only be re-fitted with the bumper off which is bloody annoying!
08 Jun 2011 16:29 #17524 by Halford
26 Jun 2011 17:27 #18288 by Halford
found some interior trim panel fixings
FIX9K RED PANEL CLIP FIXINGS CAR TRIM BODY PANEL
25 @ £4.95 free carrage
12 @ £2.95 free carrage
from easynaz on eBay
Time to create page: 0.253 seconds
