removing internal rear trim and tailgate panels
- Thank you received: 360
08 Jun 2011 05:42 #17500
by Halford
removing internal rear trim and tailgate panels was created by Halford
Hi all,
just wondered as to whether anyone could offer step by step advice or pics upon removal of internal rear side panels / and internal rear door trim - I'm looking to replace speakers and add fixings to rear door for storage (map pockets etc)
I've already convinced myself I'll snap something and sulk for the rest of the day
thanks for any help
thanks for any help
- VAXXi
08 Jun 2011 08:04 #17507
by VAXXi
Replied by VAXXi on topic Re: removing internal rear trim and tailgate panels
www.answerbag.com/q_view/1058351
Short story:
- remove rear seat bottom by pulling hard straight up (pull in front, there are two clips there)
- unclip the plastic ornaments which cover the rear seatbelt (between the rear seats, in the middle)
- you have 4 screws on the bottom (still between the rear seats)
- pull the velcro carpeting on the back of the seats, in the corner to expose the screw which holds the L shaped bracket
- now you should be able to remove the rear seats, leaving you with two more screws for the other part of the bracket
- the plastic trim in the rear is held by 2 or 3 screws and lots of plastic clips which will certainly break and will need to be replaced if you don't want to get lots of annoying buzz from the trim :pinch:
Short story:
- adamatdraycott
08 Jun 2011 08:14 #17508
by adamatdraycott
Replied by adamatdraycott on topic Re: removing internal rear trim and tailgate panels
I removed the trim to wire my tow bar in and didn't snap any clips... you just have to be careful pulling it off evenly
- Municipal Waste
08 Jun 2011 13:05 #17512
by Municipal Waste
Replied by Municipal Waste on topic Re: removing internal rear trim and tailgate panels
Two of the plastic clips in the door jam on my newer model can only be re-fitted with the bumper off which is bloody annoying!
08 Jun 2011 16:29 #17524
by Halford
Replied by Halford on topic Re: removing internal rear trim and tailgate panels
Thanks guys :woohoo:
26 Jun 2011 17:27 #18288
by Halford
found some interior trim panel fixings
FIX9K RED PANEL CLIP FIXINGS CAR TRIM BODY PANEL
25 @ £4.95 free carrage
12 @ £2.95 free carrage
from easynaz on eBay
