Corroded swivel balls - cure or replace axle case?
05 Jun 2011 20:39 #17398
by facade
Replied by facade on topic Re: Corroded swivel balls - cure or replace axle case?
Mine were as rusty as old iron: I can only do 3000 miles a year, and about 1500 of them are on wet salty gritty roads.
When I stripped them down the seals looked fine, but the bottom bearing on both sides was solid with rust from the water that must have got through the seals.
I'm hoping the smoothrite will set hard enough to not scrape off first time I go lock to lock :whistle:
06 Jun 2011 07:14 #17406
by kirkynut
Replied by kirkynut on topic Re: Corroded swivel balls - cure or replace axle case?
Use waterproof grease on the bearings and swivels. Martin sells some.
- Rockwatt
06 Jun 2011 13:17 #17410
by Rockwatt
Replied by Rockwatt on topic Re: Corroded swivel balls - cure or replace axle case?
Strip the axle, high pressure clean then take it to be powder coated! Pack the seals with silicone grease on reassembly.
Should see you good for a few years and cheeper than a new axle.
The pre shot blasting will get rid of the corrosion and the powder will fill the pits to a silky smooth finish.
- Collins
07 Jun 2011 14:59 #17472
by Collins
Replied by Collins on topic Re: Corroded swivel balls - cure or replace axle case?
After finding out the price of an axle casing today that is pretty much what I've settled on - thanks!
