sj transfer box 410 v 413
  • Cider
31 May 2011 19:34 #17152 by Cider
Replied by Cider on topic Re: sj transfer box 410 v 413
Hi
PM sent
Cheers
Pete
  • zukenutter
31 May 2011 19:53 #17155 by zukenutter
Replied by zukenutter on topic Re: sj transfer box 410 v 413
I've just done a 413 swap into my VVT Jimny. Had to swap the gearbox too as the VVT box is much lower than the Non VVT box. With the 4.3 diffs in the VVT my final combined drive is perfect for my usage.
  • NickG
31 May 2011 19:57 #17156 by NickG
Replied by NickG on topic Re: sj transfer box 410 v 413
Cider you got a PM
  • Cider
03 Jun 2011 19:51 #17296 by Cider
Hi
Found a 410 transfer box with all the props shaft, had the choice of two!!!:) :)
Cheers
Pete
  • NickG
04 Jun 2011 12:51 #17325 by NickG
Sorted Cider
no problem ,hope the install goes well.B) B)
  • panosd
04 Jun 2011 14:26 #17333 by panosd
Replied by panosd on topic Re: sj transfer box 410 v 413
If you run 215/75/15 tires with a 413 t-case you will be ok.
For bigger tires than this you need a 410 or a locklobster.
